system exec.vi issue
hi all
i have a dos program, that when run from the dos prompt (called by command.com at windows > run) works with the following syntax:
c:\imagecompare.exe c:\file1.bmp c:\file2.bmp
OR
if run from c: in the dos prompt.
i have tried every way described of doing it using system exec.vi but nothing seems to work.
when called this way the dos window just sits there with a flasing cursor.
so my first question is:
what is the name of the DLL i need for XP to show dos text?
i have tested command.com using system exec by the following command line input:
command.com /c dir
this popped the window up for about a second. but i had no std output. should i have seen output from this vi?
any help would be appreciated
(3,238 Views)
Hi slugger,
you have to use quotation marks.
cmd /c ""C:\imagecompare.exe" "c:\file1.bmp" c:\file2.bmp"" should work for you.
Hope it helps.
Mike
(3,237 Views)
hi mike
well tried all that and it still didnt work !!
got really annoyed with it and tried the following:
created image.bat with the following text inside c:\imagecompare.exe c:\file1.bmp c:\file2.bmp
then directly from the command line ran "c:\image.bat"
this worked.
thanks for pointing me in a direction i hadnt tried
(3,226 Views)
Hi slugger,
i forgot one quotation mark. Smiley Wink sorry for that.
Can you upload your vi, or a picture of it?
Mike
(3,219 Views)
hi
as i said this works.
ive also included the std output.
(3,204 Views)
