system exce command
I have an application that I would like to run in Labview. How would I run in commad prompt the applicatoin C:\Program Files\Flash\FM.exe Options1 Options 2?The directory has to be set to C:\Program Files\Flash for the exe to be able to run. I am using Windows 7 LV 2013
Message 1 of 10
(6,127 Views)
What do you mean by "Options"?  Are those specific commands or menus from FM.exe?
Not sure if you already know how to use SystemExec.vi.  If you don't, look for it via ctrl+spacebar on your block diagram.  Should look like below.
-Mitch
Message 2 of 10
(6,099 Views)
Also read the help for the system exec vi, note you will likely need the cmd /c at the beginning.
Michael
Message 3 of 10
(6,089 Views)
Hi jamridge,
  Please find the block diagram attached.
SrikrishnaNF
Srikrishna
Message 4 of 10
(6,069 Views)
Hm...now i'm curious...what's the purpose of the cmd/c?
I tested mine with cmd/c and got an error--image below.  I took out the cmd/c and it worked fine.
-Mitch
Message 5 of 10
(6,039 Views)
If you type "cmd /?" for the command switches list, it should explain the "/c":
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\>cmd /?
Starts a new instance of the Windows XP command interpreter
CMD [/A | /U] [/Q] [/D] [/E:ON | /E:OFF] [/F:ON | /F:OFF] [/V:ON | /V:OFF]
    [[/S] [/C | /K] string]
/C      Carries out the command specified by string and then terminates
It executes the command given and then terminates.  For an instance such as this, it is probably unnecessary.  I would try adding a space after the "cmd" and the "/c".  This may remedy your issue.
If someone helped you out, please select their post as the solution and/or give them Kudos!
Message 6 of 10
(6,026 Views)
MrHappyAsthma,
Thanks for that.  I was actually just beginning to reply when I received a notification that you replied.  I, too, noticed that I didn't have a space between "cmd" and "/c".  Tried it this time and I received no error.  However, the program I tested it on (called "Downloader.exe") didn't run when I had included "cmd /c".  I saw the cmd screen flicker in and out, but it never opened.  I then removed "cmd /c" and the executable opened, at which point my face went Smiley Surprised.
I'll be digging into the "why" later on.  Hopefully i'll have time later today to look into it.
-Mitch
Message 7 of 10
(6,013 Views)
It most likely is opening the "downloader.exe" that you refer to and then terminating before you see any result with your own eyes.  What does "downloader.exe" do?  And what is your end goal?
This is why I mentioned it may not be necessary for your situation. 😛  This is how the mystery of Windows cmd works.  Its not really a LabVIEW issue.
Message 8 of 10
(6,003 Views)
Well,
For my specific purpose, I use SystemExec.vi to run a specific upload function via Downloader.exe--used to work all the time until I received a couple of feedback which I am now troubleshooting...  As for the OP, not sure what his FM.exe does.
-Mitch
Message 9 of 10
(5,992 Views)
Well all I can recommend then is if the "cmd /c' is causing the command prompt to terminate before the program successfully completes its task, then exclude it.  If you prefer the command prompt to terminate upon completing its command, then use it. 😄
Message 10 of 10
(5,986 Views)
