synchronous LED display with digital output
hi,
In the experiment I want to control a relay, so I use the MAX to generate a digital output task and then transfer it to example code in labview as below. How can I amend  this code so that when the module ouput 1 there is a synchronous LED display on the front board.
Thanks~~~Cat Happy
(2,627 Views)
Use single sample digital writes inside your loop.  Use a shift register to hold the state (T or F) and invert each iteration.  Now you can just wire the state wire to a front panel led and be sure that it is sync'd to the digital output.
(2,585 Views)
