synchronizing two systems
I have two separate systems running separate VIs (Not on the same machine) and they both read and write to a shared variable.  Is there any way to synchronize the two systems that use the shared variable?
(3,345 Views)
Perhaps you can give a little more detail in what you are trying to do.  What are you trying to synchronize between the two systems?  DAQ timing?  The values of variables?
(3,324 Views)
altran,
In addition to answering Raven Fans question I recommend looking to the following links relating to timing and shared variables.
How do you synchronize accesses to a LabVIEW Shared Variable?
shared variable synchronization
Message Edited by BLAQmx on 03-26-2008 02:10 PM
Mark
NI App Software R&D
(3,301 Views)
