synchronizing two function generator
Hi ,
I am working to synchronize two function generators by LabView.The first function generator is manual triggered while the another one is external triggered like this set up (INFINITE BURST MODE METHOD  ) in this link http://www.keysight.com/owc_discussions/thread.jspa?threadID=32427
When I run the code , I see in oscilloscope the first signal from master function generator but , I can not see the signal from the second generator. I found the trigger edge is still off in Function generator while in the code I set it positive edge . I do not know why
I attached the code
Sincerely,
Abdulaziz
(3,521 Views)
Hi ,
I attached the updated code
The Function generator is Agilent 33250A
Sincerely,
Abdulaziz
(3,479 Views)
Hi Abdulaziz,
Thanks for posting this issue.  It may be helpful to include the SubVIs that you're working with as well.  I would suggest making sure you've correctly followed all the steps in that link, as there are quite a few to go through, and perhaps switching the which function generator is the master and which is the slave, to ensure it's not an issue with the devices.
Andy G
Applications Engineering
(3,438 Views)
