synchronization/ addition of tasks to
Please, can any body help me in joining the attached taks to be in one code?
I have attached my main appklication of aquiring voltage signal triggred by digital signal.
I would like to join the other two attached application to my main application in the same code and to share the same trigger sourse.
by the end I would hjave three analog signals triggred by digital start trigger syncronized at the same time and sharing the same internal clock. the samplingrate will be the same for all signals.
your help is highly appreciated as I am in urgent need for your help.
(2,403 Views)
Hey,
I don't think that anyone here will make YOUR WORK.
You should have a look at the synchronization examples under ....\LabVIEWX.X\examples\daqmx\synchronization and try to combine your code.
Christian
(2,382 Views)
