sync a time loop with a simulation
I am trying to sync two timed loop (one normal and one with simulation) the number on reach about 3800 after the runs. If I use 2 time loops, I can reach 3999 (sometimes 3998). I am using windows XP to run? Do you have any idea about this problem? Will RT be better to run this?
(2,742 Views)
I'm curious if you are finishing on time with your timed loops.  Use the "finished late?" flag to see if it is running long and create a way of counting how many times it finished late.
Windows can take over and throw off the timing of timed loops.  RT would alleviate this.
Justin Parker
Product Support Engineer
(2,703 Views)
