switch with debounce
Hi everyone,
I need to make a switch that does the following when clicked:
1- switch on
2- wait for 60 ms
3- switch off
i am new to labview so anything would help.
Thank you
(6,141 Views)
Hi Shahramk6
U can use aciveX control for it (if u really need this bounce logic to be in control), else u can program the logic such that , once the switch is pressed after 60 sec changing its property to off
(6,112 Views)
Accepted by topic author shahramk6
Use a Boolean control with "Switch When Pressed" mechanical action and a local variable (resetting it) in the Timeout case of the Event structure.
Jim
(6,080 Views)
LOL sounds like you did someone's homework.  😉
Bill
CLD
(Mid-Level minion.)
(6,058 Views)
If this is homework, you shouldn't use Local Variables (read this post to understand when to, and when not to, use them).  Here's a way to do it without locals:
You can probably figure it out for yourself, but the string constant contains "\01\01\00\01\01\01\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00\00".
Jim
(6,029 Views)
I accept risking losing the solution and kudos by posting this, but my second post in this thread was intended for the entertainment of experienced LabVIEW programmers; it is intentionally obfuscated.  I apologize for making you the butt of my weak joke.
Jim
(5,976 Views)
I really hope this is the solution handed in.  That being said I think you'd get more kudos for posting obstruficated code.  If you answer for the OP you get one kudo for each post max.  If you post obstruficated code you likely get kudos from your peers that think it's funny.
(5,961 Views)
