switch logic in cluster
Hi... i am using switch logic in my VI within cluster, Pls check my VI.
If i use this logic in slow performance system, some times the button doesnt release automatically.
Can some one suggest better logic using cluster.
thank you,
Ranjith
(3,090 Views)
you can ignore my quesion w.r.t performance issue...   if there is a better way to do it pls welcome...
Ranjith
(3,080 Views)
Isn't this better ?
Also change the mechanical action of the button, to switch when released
(3,078 Views)
I cant change the button mechanical action.  Any how thanks for that.
(3,052 Views)
Hi Ranjith,
When you say better, what exactly are you trying to achieve? And why are you not able to change the button mechanical action?
Warm regards,
Karunya R
(3,019 Views)
The vi works fine and should not have any problems, in any machine.
(3,004 Views)
