sweep and implementation of exponential signal
hi everyone
i have some problem to give sweep of signal from -pi to +pi.valus of pi is -180 to +180.i have to give sweep and plot the array on the graph.pls help someone how do i plot it either using loop or there is some other technique as well
(1,075 Views)
Hi rafi,
pi typically is not equal to 180, but ~3.14159…
Use the Ramp function to create your "sweep" from -pi to +pi.
Then use a waveform graph to show the resulting array…
What have you tried and where are you stuck?
(1,062 Views)
thks for your suggestion.i am stuck at implementation of linear array factor at 0 degree.my output would look like major lobe adjacent to minor lobes i mean beam of radar
(1,043 Views)
Hi rafi,
What is a "linear array factor"?
What is a "factor at 0 degree" and how is it related to a LabVIEW array datatype?
What exactly have you tried and where exactly are you stuck? (To rephrase this question: Why don't you attach your VI???)
Why are you talking now about radar lobes, when you want to create an array and plot that array on a graph?
Again: where exactly are you stuck???
My glassball is broken… 😩
(1,041 Views)
