swap elements in 2d array
I'm looking for a way to swap a user-defined length of elements in a 2-dimensional array between rows. All of my efforts so far only take the elements and move them within the same row.
Basically I have a 2d array with 2 rows, and I want to take a few of the elements from one and put them in the other, getting a new array that has elements of both. This needs to be expandable to any number of rows.
Thanks for your help.
Message 1 of 17
(8,726 Views)
A quick example-
This will take Length elements from Start index and reverse the row that tha data is in.  e.g Start 1 length 2
0 1 2 3                     0 3 4 3
4 5 6 7    Maps to     4 9 0 7
8 9 0 1                     8 5 6 1
2 3 4 5                     2 1 2 5
Maybe not exactly what you want but some food for thought.  A Z delay FBN would allow shifting rather than reversal
"Should be" isn't "Is" -Jay
Message 2 of 17
(8,717 Views)
I'm sorry I'm not a very advanced user, can you explain in a bit more detail how something like that might be done?
Message 3 of 17
(8,711 Views)
Oh, He77!
I, of course, meant to ATTACH the exampleSmiley Very HappySmiley Very Happy  That is on my work PCSmiley Sad  I'll post it first thig in the AM
Sorry.
Message 4 of 17
(8,697 Views)
Something like this? (see attached)
CLD Certified 2014
Message 5 of 17
(8,686 Views)
pretty close.  I did it with nested IPE structures I'll post the example in an hour or so
Message 6 of 17
(8,668 Views)
Like this... Simple.
CLD Certified 2014
Message 7 of 17
(8,660 Views)
Accepted by topic author jgor
The OP did require the ability to expand to additional rows.
This example shifts row data down by "Shift"
Message 8 of 17
(8,655 Views)
Thanks I should be able to do a lot with your solution, Jeff. I've never used IPE structures before. I'll start figuring these out.
Message 9 of 17
(8,641 Views)
Here is what I came up with. It allows for single element swapping.
CLD Certified 2014
Message 10 of 17
(8,634 Views)
