supercool pr-59
Does somebody have a driver or an example to control the temperature controller PR-59 from Supercool?
V.
Message 1 of 10
(7,066 Views)
I think the best thing you have to do, is ask the manufacturer... He may give you exemples.
Regards
Richard Keromen
Message 2 of 10
(7,038 Views)
Hi, Sorry I do not have any help for you. I am however going to use one of those in about 2 weeks or so, so if you find anything or make anythign yourself, it would be great if you posted it here Smiley Happy
Message 3 of 10
(7,032 Views)
Here comes the commands listing from the manufacturer.
I've made some tests and it's working.
Cheers,
V.
Message 4 of 10
(7,022 Views)
Hello Vloom,
I also have a project with a PR-59, could you help me and sent your drivers you programmened?
Thank you very much in advance pascal.heinen@ingeneric.com
The Enrichment Center is required to remind you that you will be baked, and then there will be cake.
Message 5 of 10
(6,863 Views)
Hello Heinen,
I don't use this regulator anymore because it is not compatible with standard K or J thermocouples.
The simple joined vi returns a temperature or something... I'm sure it will not help you... sorry Smiley Sad
V.
Message Edité par vloom le 07-10-2008 09:38 AM
Message 6 of 10
(6,840 Views)
Hey, thx you for your quick reply, I will look in it soon!
Message 7 of 10
(6,835 Views)
And?
Did you look into it?
If you have a driver now, would you mind sharing it?
(I know this thread was posted a long time ago...)
Message 8 of 10
(5,836 Views)
Here you go! Try the commands from the list provided by the manufacturer! The basic commands are $W, $Q, $R0=nn.n, ...each command requires return sign. If you want to implement it as SubVI, make sure you have configure the controller accordingly. And use a delay between each of the commands! To get the temperature of the sensor, search for the echoed request "$R100?" and leave out the returns and line ends.
Message 9 of 10
(4,914 Views)
Thanks for sharing.
Do you mind to upload a LV2011 version?
(meanwhile I did some work myself, but I'm always interested in the other people's point of view and solutions)
Message 10 of 10
(4,895 Views)
