sunny boy using labview
Hello my name is Akram!!!
plz Is there anyone could help me ,, How i can simulat sunny boy by using labview software
Message 1 of 22
(4,556 Views)
how I can simulate sunny boy DC to Ac inverter by using labview
Message 2 of 22
(4,539 Views)
Your questions is WAY too vague. Simulation for what purpose?
Is this a real project, or just another school assignment that we keep getting flooded with and people think we can't recognize them as such?
How To Ask Questions The Smart Way
Message 3 of 22
(4,535 Views)
Thank u for replying me..
simulation DC to Ac inverter to use it for complete my project which is that use micr-grids to generate the electrecity in terraced houses by using solar panel as source ............... This means that I need Dc to Ac inverter to invert the power from DC to Ac .............
Message 4 of 22
(4,524 Views)
Yes, I know what an inverter is. You've said where you're using it, but you have not said anything regarding what kind of simulation you are trying to do. Obviously, you need a simulation model. Do you have one? If not, that's where you need to start.
Nobody here can help you unless you provide specifics. We are not mind readers.
Message 5 of 22
(4,475 Views)
I am going to simulate micr_ grids in terraced houses by using solar panel as supply to generate the electrecity by using labview software ......it is simply simulation the whole project by using labview software  ........... as I mentioned before the PV will produce dc power and this power will be saved in the specific kind of battery and this dc power will be sent out to the houses through dc bus and we will use dc to ac inverter to invert the dc power to ac to use it for any thing runs by ac power.
Message 6 of 22
(4,468 Views)
Does the inverter you want to model have any kind of phase or amplitude control? You need those, especially the phase control to tie to the grid.  Unless the manufacturer of the inverter has put a lot of effort into grid modelling, I suspect that you will find little relevant information available.  You may need to test the inverter's phase behavior and create your own model.
Lynn
Message 7 of 22
(4,463 Views)
Sunny boy inverter will be used in this broject(Micro grids).........
Message 8 of 22
(4,455 Views)
Perhaps you might want to consider actually putting down some information to replace all those dots .....................................................
Message 9 of 22
(4,450 Views)
Sunny boy makes many different models of inverters.  Only you know what inverter you are using, we have no idea.
Did you read the link  provided?
Message 10 of 22
(4,446 Views)
