sum low pulse width over fixed time period
I'm using a NI cDAQ-9178 with the NI 9411 DI module.  I'm looking to read a (not very clean) ~100kHz square wave
signal and sum the low pulse width (1-3us each) over a 5ms period.  The falling transition is relatively clean, but
the rising transition is a bit slow (0.5-1us).
Any advice on how to code this?  I've looked at the counter examples for measuring pulse width and semi-periods,
but the values I get with those examples do not match what I measure with an oscilloscope.
Anna Liao
(3,162 Views)
Hi Anna
It does not sound like you are receiving any errors, but maybe the suggestion provided in the document I Get Error -10920 When Counting Square Waves without an Adequate Rise Time can help in your application. It sounds like it could explain why your values do not appear correct.
Milan
(3,136 Views)
Hi Milan,
Thanks for the reply.  Actually, I just used the measure semi-period finite with fixed number of samples.  I adjusted the number of samples so that I get a total duration of approx. 5 ms.  I then just sum the respective arrays for low pulse widths and high pulse widths.  The values seem to match what I get from the scope, so I think this is a reasonable way to approximate the measurement I am interested in.
Anna
(3,126 Views)
Hi Anna,
I am glad that you found a workaround that helps for your application and shared it with us!
Have a Great Weekend,
Milan
(3,117 Views)
