subvis terminates when two while loops run parallely
i use labview 7.1
in my program i use two while loops..runs parellely..
one loop has mymain program..other one is two abort the motion abruptly..
my vi runs properly..when i remove the second loop..but terminates...while communicating with a fn generator  when two loops run parallely..
can anyone help me.?
Message Edited by fella on 03-21-2007 09:02 AM
Message 1 of 8
(3,413 Views)
I think you're going to have to post some code that demonstrates this behavior.
Message 2 of 8
(3,404 Views)
Hi fella,
as said in a different thread: Please provide source code to look at!
Message 3 of 8
(3,403 Views)
sorry....i cant send any code...
can u help me with the information i provide..
my vi runs succesfully without the additional loop...when i run both loops together...both works but my second case infirst loop doesnt  work properly..
i can send u the details...not the code
if u think u can help me..
do reply
Message 4 of 8
(3,387 Views)
I think you have to provide more information. You can try to rip off the confidential parts from your code and simply leave the components that cause the trouble,
Tomi
Tomi Maila
Message 5 of 8
(3,381 Views)
its not tat...
i dont have access to labview here....i am doing project at a diff institute .
i will tell u where i have the problem
in one of my case structure..the actions r..
 activate a trigger source....viz a fn gen
then take readings from a digital multimeter..
this is my second case..
my first case..where i reset a turntable to a certain angle..works properly along with the parellel loop.
but when i execute the second case..its shows error while communicating with the trigger source..
when i run the case alone...without the parelel while looop..it executes succesfully...
hope u got me..
thanks for the help!
Message 6 of 8
(3,377 Views)
Please understand that we cannot help you unless you can provide us code. If you cannot send the code, they I'm afraid that there is nothing we can do. And please do not use abbrevations as it makes your text hard to read.
Tomi
Tomi Maila
Message 7 of 8
(3,372 Views)
thanks...
i will send the code..as soon as possible..
Message 8 of 8
(3,368 Views)
