subvi
hi
Question:
Can i create an empty subvi?
My purpose is when i start a big program from scratch, i start from the big picture. Then, i create several small subsystems, which are obviously empty in the beginning. then, i will fill up those subvis. Then, continue to smaller one. Hence, this hierarchical metho is better.
(3,410 Views)
Yes.
(3,406 Views)
To add a bit to Ravens Fan's answer, you might add Front Panel controls & indicators so you can wire them together and show what data types you plan to use.
Jim
(3,384 Views)
I think you can just put a while loop and a stop button for a vi.(with a bit of delay.. else your system performance will be shooted to 100%). later you can think of the controls and indicators....
LV 8.0, 8.6, 2011,2012,2013 WinXP
(3,378 Views)
LabVIEW even has a bunch of vi templates you can use to speed development a bit.  For instance, there's one with error in and error out, already connected to a standard pattern in the expected the locations.
Bill
CLD
(Mid-Level minion.)
(3,355 Views)
