Yes ther is a "trick" no it is not a trick but the way that it has to be done. what you have to do is right click on the icon in the top right hand corner of your vi. then select show connector. It is probably blank on yours, then all you have to do is click on one of the inputs and then click on the control or indicator that you want at that point. Just remember when creating a subvi all controls will be inputs and all indicators will be outputs. also a good rule of thumb is to put inputs (controls) on the left and outputs (indicators) on the right.
The manual states this also.
Joe.
"NOTHING IS EVER EASY"
