subpanel scollbars in labview 8.0
HI
I Just installed Labview 8.0 instead of 7.1. I my VI i use a lot of subpanels, with no scrollbars but when i compile my vi to 8.0 scrollbars are added to the subpanels, and i  cant find an option to disbale them..please help..
thnx
Bart B
Labview CLD , Engineer/Manager
Promedes and DSM
using LV 7.1, 8.0, 8.2, 8.5 and 2009 SP1
http://www.promedes.nl
(3,771 Views)
Hi Bard,
The Scrollbars are not part of the Sub Panel but the VI. If you want to remove the scrollbars you need to disable them on the VIs that you load in the subpanel. This can be done by opening the VI, Select File -> VI Properties. In this window choose the Window Appearance category. Click the Customize button and in this window you can disable the scrollbars.
The scrollbar options on the VIs changed from 7.1 to 8.0, It is now possible to enable / disable the horizontal and vertical scrollbars independent.
Hope this Helps,
Karsten
NI
(3,757 Views)
Sorry to revive such an old thread, but although following the steps mentionned by Karsten, the scrollbars still appear in the sub panel.  😞
Using LabVIEW 2009 SP1.
(3,335 Views)
I'm reviving this old thread and I'm not sorry.
You have to edit the scrollbars directly on the front panel of the subvi being inserted into the subpanel. right click the scrollbar and select "always off".
https://www.eehelp.com/question/how-to-remove-the-scrollbars-panel-sub-with-labview-2009-sp1/
(1,378 Views)
