subarray elements addition
Message 1 of 16
(4,140 Views)
Please give some more details about what you are doing. Just by heading "subarray elements addition" didn't give more details.
Message 2 of 16
(4,137 Views)
Hope this helps....
Message Edited by Vsh on 05-27-2008 02:23 AM
Message 3 of 16
(4,131 Views)
hi,
         Thank you so much. i have one more doubt regarding array addition. I want to add the consecutive array elements & this process must be controlled by an add button. i.e. say, array given is {0,1,2,3,4,5}. I want the addition as follows : {0+1}, {1+2}, {2+3}, {3+4}, {4+5}. The addition must be done iff add button is enabled.
Message Edited by Sithu on 05-27-2008 02:39 AM
Message 4 of 16
(4,121 Views)
Hi Sithu,
try this example. Where do you need the button?
Mike
Message Edited by MikeS81 on 05-27-2008 09:44 AM
Message 5 of 16
(4,113 Views)
Here's another possibility.
I don't understand your requirements with the button.
Maybe you can use a case structure and place the algorithm in one case while wiring the input array across in the other case.
Maybe you want an event structure.
Please be more specific.
Message Edited by altenbach on 05-27-2008 12:58 AM
Message 6 of 16
(4,107 Views)
thanks Mike... Ill explain clearly.
1. the user can input an array of any dimension.
2.the addition must be performed as per the logic you said.
3.the task must be performed when the user presses the add buttton.
4. when the button is released the task is stopped.
5. addition process is resumed when the user again presses add button.(result till the previous addition is stored in a buffer.)
Message 7 of 16
(4,101 Views)
i have included the details. any idea?
Message 8 of 16
(4,082 Views)
Hi Sithu,
here is an example, but where do you need it?
Mike
Message 9 of 16
(4,061 Views)
Thanks Mike... actually my boss gave the question to work out.
Message 10 of 16
(4,049 Views)
