subVI Visibility
I have inherited a large (1000+ VIs seems large to me) TestStand project wherein many of the subVIs are visible. How can one determine by inspection the process used for making a subVI visible? I am fairly new at this but I think there are at least a couple of ways of doing this. I remember seeing a couple of things about it but failed to make a mental note as I was waist deep in alligators of another sort at the time. Seems like there is a visible when running and a bring to front method but can't seem to find them.
jvh
(4,018 Views)
Accepted by topic author jvh75021
jvh,
when talking about "visible", i suspect that you mean "popup", in other words: when called, the VI shows it front panel. Correct?
If so, there are several places where this could be configured. But most often, the popup-functionality is configured in the VI itself (VI settings >> Appearance). So this would be the first place for me to look into.
hope this helps,
Norbert
Norbert
Expert: Geometry
(4,010 Views)
In LabVIEW to make the front panel visible you use an Invoke Node.
Select the VI class and then select the Front Panel Open method and wire in the states.
But also if you are calling these VI from within TestStand you will also need to add the
TestStand - Start Modal Dialog.vi and TestStand - End Modal Dialog.vi to get the VI
to pop up in front of your TestStand Window.
If you don't a lot of the time the VI will open up but will be behind TestStand and you will not see it.
Omar
Message Edited by OmarGator on 02-23-2010 08:27 AM
(4,009 Views)
VI settings >> Appearance??  Couldn't find that but it gave me a clue. Maybe this is it: File > VI Properties > Window Appearance > Customize...  Show front panel when called
 Not sure I would have hidden that check box so deep and under Customize...
Thanx again,
 jvh
(3,998 Views)
Thanks, Omar.
You may have unknowingly solved another problem for me.Smiley Happy
With this project if one is not careful with the mouse or looking at something unrelated to the test we sometimes have dialogs get hidden and minimizing everything in sight will not reveal them and there is no task bar anchor either.
Now I must investigate Invoke Nodes....
Wish I could select 2 answers as solutions.
Thanks again,
jvh
(3,995 Views)
No, you do not need to use Invoke Nodes to make the front panel visible in LabVIEW or TestStand. Just use the VI Properties. Making the VI a dialog will enable the front panel display as well as making it modal to LabVIEW. Do make sure to use the TestStand Start/End Modal Dialog functions.
(3,982 Views)
