sub vi
Hi ,
I am new to the labview
How to connect two terminals of different types
Message 1 of 8
(3,761 Views)
hi desham
give some more detail what u want to do
as i understand u want to connect to different data type
for that u can use build array or u can see in array pallete also there id dynamic data convertor
hope u will done
tc
Message 2 of 8
(3,753 Views)
From text to number or back e.g. you can use Scan from string in the string pallete. If that doesn't solve it we'll need more info.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 3 of 8
(3,743 Views)
Hi ,
 if i use dynamic converter the output is changing
can u please look at this block diagram
Message 4 of 8
(3,714 Views)
You didn't attach the sub vi's, else i dont quite understand what you mean.
/Y
Qestit Systems
Message 5 of 8
(3,696 Views)
Hi ,
 Here is the sub vi
Message 6 of 8
(3,676 Views)
Apart from the recursive call to Test3 the vi seems to run fine. Should you change to dynamic data the results change as most functions are polymorphic. Somehow i dont think that's what you're after in your question.
/Y
Qestit Systems
Message 7 of 8
(3,663 Views)
Can you give us some more info?
You are trying to change from what to what?
Dbl --> Str
Str --> 1D array
I8 --> I16
Cory K
Message 8 of 8
(3,646 Views)
