struct with pointer
Hello I need to interface with a DLL with the folowing structure:
extern "C" {
struct IDSTRUCT
UINT8 code[2];
UINT8 signature[8];
UINT8 revision [4];
R2DLL_API BOOL R2DLL_ReadFirmwareHeader (UINT16 port, struct IDSTRUCT* pStoreAdr);
Is there a way to implement this with clusters in labVIEW?
Thanks in advance
(4,237 Views)
the way to go isn't the easiest! Define an U8 array of lets say 50 elements( Contains al necessary bytes + an extra 4), cast it to a string and wire it to the dll terminal(= C String Pointer). The information retrieved is mangled in the string return string. Simply do some byte manipulation ( big/little endian enc.) and you'll have your info.
LabView handles strings like { u32 length, u32* pointer). Refering to above the length long introduces the extra 4!.
Try It
Ruud
(4,211 Views)
> extern "C" {
> struct IDSTRUCT {
> UINT8 code[2];<br>
> UINT8 signature[8];
> UINT8 revision [4];
Yep! Create a cluster with an UINT16, and three UINT32. Then you have
all the information. Typecast the UINT16 and the last UIN32 into a
string, and combine the middle two UINT32 into an array, and typecast
them into a string too.
Rolf
Rolf Kalbermatter  My Blog
(4,185 Views)
I'm not sure how to handle structs with unions with another struct inside.  I'm new at LabVIEW
what if the structure was like this:
#pragma pack(push, 2)
struct IDSTRUCT
   UINT32 temp;
   union
      UINT32 x;
      struct
         UINT32 x1    :1;
         UINT32 x2    :31;
   union
      UINT32 y;
      struct
         UINT32 y1    :1;
         UINT32 y2    :31;
#pragma pack(pop)
(3,978 Views)
"mudder" <x@no.email> wrote in message news:1171469412642-478205@exchange.ni.com...
I'm not sure how to handle structs with unions with another struct inside.&nbsp; I'm new at LabVIEW
&nbsp;
&nbsp;
struct IDSTRUCT{
&nbsp;&nbsp; UINT32 temp;
&nbsp;&nbsp; union
&nbsp;&nbsp; {&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; UINT32 x;
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; struct
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; {
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; UINT32 x1&nbsp;&nbsp;&nbsp; :1;
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; UINT32 x2 &nbsp;&nbsp; :31;
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; };&nbsp;&nbsp; };
&nbsp;&nbsp;
&nbsp;&nbsp; union
&nbsp;&nbsp; {&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; UINT32 y;
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; UINT32 y1&nbsp;&nbsp;&nbsp; :1;
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; UINT32 y2&nbsp;&nbsp;&nbsp; :31;
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; };&nbsp;&nbsp; };};#pragma pack(pop)
This is basically a pointer to four U32's. Because it is a union, the pointer can point to:
temp { x {x1, x2 } }
Or:
temp { x {y1, y2 } }
I'd use a cluster with 4 U32's. The sub structures have no size, and can be ignored in LabVIEW.
Wiebe.
(3,950 Views)
