strip chart only displays 2 seconds of data
I am using LV 8 to acquire data thru 2 analog inputs.   I can only see a max of about 2 seconds of data using the scroll bar in strip chart.  How can I see the full strip chart of 60 seconds or more of the data?
Thanks.
hellolv
(2,640 Views)
Increase chart history length!
Right click on the chart, in pop down menu, select chart history length.
It will be set to 1024 points by default.
Depending on your sampling rate and number of second's data you want to see on chart, calulate a history length and update here. Now you can use scroll bar to see past values
(2,631 Views)
Thanks much.  Worked like a charm!
(2,628 Views)
