string wildcard
Spoiler
I want to search for all word beginning with 'b' and ending in 's', e.g. boris, bolivians, beings, etc.
In DOS I could look for b*s but in labVIEW there does not appear to be a wildcard that ignores the middle length.
I could use 'b.s',  'b..s', 'b...s', etc.
Is there any simple way of doing this without having to do the above?
Sean
(8,871 Views)
Check out the Match pattern help - I admit it takes a little deduction to discover.
"b[a-z]+s" will match lowercase words starting with b and ending with s.
Visualize the Solution
CLA
LabVIEW, LabVIEW FPGA
(8,861 Views)
Accepted by topic author SeanJ
b[a-z]+s will match words beginning with b and ending with s but will also match section of word in some cases, as an example it will match "bus" in abusive. To insure match on whole words only you should use the match regular expression vi (it gives you more options for matching strings) with word boundaries \b to your search expression: \bb[a-z]+s\b
Ben64
(8,850 Views)
Thanks ben64,
I just couldn't remember!  The exact equivalent id * = [^]+
Sean
(8,819 Views)
Sorry, that should have read thanks Dave.
Thanks to you both, S
(8,816 Views)
