string to floating point conversion with leading zeroes
hi, i'm running LV 6i (6.0) and am trying to convert a string from a serial connection into a floating point number. The thing is the number value i'm trying to convert is 10(-3) (e.g. 0.001539). I ultimately want to get it to 1.539.
any help?
(2,710 Views)
I'm not sure I understand your question :
- could you simply multiply the floating point by 10^x ?
- Have you noticed that there is a series of vis dedicated to string to number conversion (in the string sub-palette) ?
Chilly Charly    (aka CC)
(2,696 Views)
Hello tsi,
As Chilly Charlie already mentioned, there is a function on the String sub-palette called "Scan From String." If you place it on your block diagram and double-click, you'll get a configuration page that will help you format you number appropriately. Alternatively, you could using the format string input. This webpage describes how to use it:
Hope this helps!
Charlie S.
Visit ni.com/gettingstarted for step-by-step help in setting up your system
(2,678 Views)
