string to 2D string array conversion
It's not a String, it's a 1D Array of String.  I just don't show the Index Display (to save space).
By the way, what version of LabVIEW are you using?  If you're using 2009 or 2010 you can simply drag my code snippets onto a Block Diagram and you'll have my code.  You don't need to re-wire it.  (You can still get the snippets if you're using an older version of LabVIEW, it just requires a tool I wrote to extract the code from the image.)
Jim
Message 21 of 23
(1,058 Views)
I have added array constant with string constant. Now i am getting attached image. Now how to remove the array constant.
Kalyan
Message 22 of 23
(1,048 Views)
Right-click on the Array Constant, select Visible Items and de-select the Index Display.
Also, you need to start throwing some Kudos around when answers help you.
Jim
Message 23 of 23
(1,041 Views)
