string ring menu ring
One function I have found super useful is the string ring, but I can't find it!  The menu ring is pretty easy to find, right click on the front panel and it is listed right there under text controls.  But, every time I want a string ring, I have to go into a vi I got help with on one of these forums and copy/paste it in, which is silly.
Also, if I have a menu ring constant (like the one below), is there a way to convert it into a string ring constant (which I also do not know how to make other than the very roundabout way of making a sub.vi with a string ring input and creating a constant) without having to re-type all of the values?
(9,201 Views)
Jargon is important sometimes. The String Ring is called a Combo Box and I like them a lot as well. To create the constant I usually start from a control and either create or change to a constant.
(9,195 Views)
Its called a "Combo Box" on the string and path controls palatte
"Should be" isn't "Is" -Jay
(9,194 Views)
Thanks, now is there a way to convert an already made menu ring into a combo box (and the same with their equivalent contant forms)?
(9,187 Views)
no,  the combo box item editor (and menu and enum item editors) that ship with LabVIEW do not live up to expectaions.  I imagine that some people have a "roll your own" plug-in handy that adds functionality like multiple separators, blank values, duplicate values, and string to number conversions. Feel fre to vote on this idea
Type cast might be fairly easy to move some of the items though (as Darin is probably typing at the moment)
(9,180 Views)
No Type Cast here, just a couple of properties:
(9,175 Views)
I think you can just use the property nodes. For a menu constant, first "create control" then populate the combo box control, then "create constant."
Edit: Nevermind, Darin got to it first
(9,174 Views)
