string number to hex number conversion problem
hello,
i have a conversion from a string number array to a string hex array conversion problem.
first i take the string number array and then convert it to a numeric number array and then to a hex string array.
this is what i am getting through for the conversions.
string number = 1111
numeric value = 1111
hex value        =  457
i was expecting F
i attache the vi because it seems easier to understand visually
(4,624 Views)
The number 1111 is 457 in hex
The number 15 is F in hex and is 1111 in binary
Message Edited by Matt W on 09-01-2006 05:29 PM
(4,617 Views)
You just need to scan the input number as a binary formatted number. (You try to read it a decimal: one thousand one hundred and eleven).
(See attached modification, LabVIEW 8.0)
(4,606 Views)
Unfortunately,
I don't have LV-8.x and cannot see Altenbach's vi.  Most likely very elegant 😉
Here is a version in LV7.0.
RayR
(4,602 Views)
Yup, mine's a bit simpler ;).
(he actually wanted a hexadecimal formatted string output. So the "first half" of my code is about equivalent to yours. If the binary string has more than 8 digits, we would need to change to a longer integer type, of course)
Message Edited by altenbach on 09-01-2006 06:27 PM
(4,600 Views)
Very nice Altenbach,
I like it.  I didn't know if there was a maximum lenght to the binary string which is why I start with the string length.
Thanks for the image.
RayR
(4,579 Views)
Thank you very much
(4,517 Views)
