string input to CIN is missing?
Using a debugger to look at the input arguments to a CIN (string and Int32), I notice the input string is not there but the Int32 has the right value. The string is passed in as a block diagram constant, not as a front panel control. Does this matter? Would a byte array be better?
(2,615 Views)
CINs are a pain.
Whenever possible, use a Call Library Function (CLF) instead. Things will go much smoother for you. If you have LV 7.0, there is a shipping example called "Call DLL.vi" in the \examples\dll\data passing\Call Native Code.llb. This example is an excellent resourse, and should address any issues you have with calling external routines from LabVIEW.
(2,615 Views)
