string convert
hi
just a stupid question maybe ...
but i'm missing some string convert functions.
e.g. i habe a list with something like:
text(space)text(space)text(spacespacespace)text
and want to convert one (or more) space(s) between the text into ONE tab.
i didn't found any function that makes me able to convert that so that i get
as a result:
text(tab)text(tab)text(tab)text
maybe someone has an idea?
thanks,
(3,258 Views)
Use the VI located in the LabVIEW directory
examples\general\strings.llb\Search String and Replace- General.vi
Set the old pattern to replace [\s]+
Set the new pattern to tab.
[\s]+ is a regular expression that means to the "Match Pattern" function:
any non-empty sequence of spaces.
Jean-Pierre Drolet
Tobias Theune a écrit dans le message :
396c6aad@newsgroups.ni.com...
> hi
get
> as a result:
> text(tab)text(tab)t
ext(tab)text
> thanks,
(3,258 Views)
Hi Tobias,
use the functions "Scan from string" and "Format Into String"
with the format strings "%s\s%s\s..." and "%s\t%s\t..." like
in the VI attached to this mail.
maybe that helps you
best regards
Guenter
Tobias Theune wrote:
> hi
> as a result:
> thanks,
(3,258 Views)
