string control KeyFocus
My Focus don't get off my string control. When I let it loose focus the VI goes on. I attached my VI.
Message 1 of 14
(5,469 Views)
What do you mean "don't get off my string control"? What exactly do you want to do. Can you explain?
Nitzz
Message 2 of 14
(5,462 Views)
When the barcode finished scanning the VI needs to stop.
Message 3 of 14
(5,459 Views)
I dont see any scaning in this program. Its just that you are typing the bar code into the string control. If you just want to stop the program after typing the bar code into the string control, just press enter after typing it. This will generate the termination charecter and while loop will be stopped.
Nitzz
(Give kudos to good Answers, Mark it as a Solution if your problem is Solved:smileywink:)
Message 4 of 14
(5,451 Views)
Ah.... 🙂 .... Instead of typing, I scan the code. And indead it set a termination (\n) sign after scanning the BC. U will see that it stay running after scanning untill u put the focus away from the control.
Message 5 of 14
(5,447 Views)
Isn't this the complete code which you are working with?
How are you scanning the code and can you show me the scan results?
Also try the attached VI.
Nitzz
Message 6 of 14
(5,440 Views)
hehehe... 🙂 ... U let the user click away fome the control.... It's purpose is to go automatic... only scanning and the VI stops...
Message 7 of 14
(5,436 Views)
I have done alot of bar code stuff.
I create a string control and a "Submit" button that I connect to a case structure (I only have BDS version of LV). I then bind the "Enter" button on my keyboard to the "submit" button. In LV the enter-key is called "Return".
My barcode scanner sends \n after the code, which triggers the submit button. This is a good way to do it, because if the bar code is unreadable, you can still input the data and just press enter on your keyboard.
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
Message 8 of 14
(5,434 Views)
Hi JoVMo,
As long as you wont explain your code well enough, I don't think anyone can help you solve your problem. You have attached a code with a couple of controls and indicators wired to each other and want someone to guess how does it work and then solve your problem. You say that the code is being scanned, but what i am trying to ask you is how is it being scanned? Do you have a hardware for that or you are using a camera and IMAQ for this using LabVIEW?
Nitzz
Message 9 of 14
(5,430 Views)
Here you go
Nitzz: He uses a bar code scanner, since it sends \n I guess.Like this one
Even
Topro AS
Norway
Message 10 of 14
(5,426 Views)
