string case
I have the attached case being ran by a combo box, but when I run the program with the combo box on X it does not seem to do what is in the "X" case.
Why doesn't this work?
(2,798 Views)
Your VI works exactly according to what you have programmed.
There my question: What did you expect to see?
I see (when setting Plane of Motion="X" and X-Direction=False) the output U32 toggling between 0 and 2. The U32 output toggles between 0 and 3 on X-Direction=True.
BR, Guenter
(2,786 Views)
Maybe you do not "see" how your vi works because there is no indicator connected to the numeric value which is handled in the cases.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,772 Views)
