string array into number
I am trying to get this array of strings into numbers, from the attached file. I just need that table of values from the file.
Any help?
(4,510 Views)
Accepted by topic author agyna
You cannot directly read a file saved in the Excel format.  You need to save the spreadsheet as a tab delimited text file.  And after that, there are some minor tweaks that can be made to your VI to get what you want.
(4,502 Views)
Perfect!
Thanks a lot.
(4,492 Views)
Oh, and it's not an Excel spreadsheet, so don't name it *.xls.  Use *.txt instead.  It's a text file.  *xls will fool a computer that doesn't have Excel into thinking it cannot read it, when it is actually perfectly readable with notepad.
Bill
CLD
(Mid-Level minion.)
(4,467 Views)
Bill;
If I may ask a follow up question: I have a table of numbers much like the above section. How can I extract the values from, for instance, the first column, first row and first column third row? I've got a string of tab delimited information, I can get it into a chart, but I cant seem to find a way to retrieve (just) the first and third value.
i appreicate your thoughts.
(4,301 Views)
Index Array
(4,289 Views)
