string array format in to special string
Hi @all,
how is it possible to format a 1-d-string array in a string which is devided after 8 characters through "," and after the 32 character through ";"
for example:
Array: 123456781234567812345678912345678 ------FORMAT-----> 12345678,12345678,12345678,12345678;
Thanks a lot,
CU Thomas
(3,169 Views)
Are you assuming that the array has one digit in each array element (I can't open your VI, I've only got LV 6.1)?
This VI should do a conversion assuming the array has exactly 32 elements, each with a single digit.
Hope this helps
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(3,162 Views)
Hey,
thanxs it works fine!
Cu Thomas
(3,159 Views)
Just an improvise one 😛
Hope this helps in one way or another.
Others may have better solution(s)
Cheers!
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(3,158 Views)
