strain measurment
hi
my project is to calculate the displacement or strain of cantilever beam by using a piezoelectric sensor, i am using DAQ 9215  to acquire signal .
i need to convert the voltage from the pzt  sensor to strain or displacement is their any way to do that in labview software
(3,417 Views)
Are you reading the sensor directly, or are is there a vendor supplied signal conditioner? If reading them directly, bear in mind that they are very, Very, VERY susceptible to noise. That sensor should come with a conversion factor in (I think) microstrain/V. It's been a few years since I have worked with them.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,395 Views)
Oh yes, what is your application?
Mike...
LabVIEW Champion
(3,393 Views)
To add to Mike's questions, are you using the 9215 in a cRIO or cDAQ chassis?  If you are using the 9215 in a cDAQ chassis and you find that there is a direct conversion from Volts to strain then you can use DAQmx scales.
http://digital.ni.com/public.nsf/allkb/0464919A11C092E386256D800079C3BB
But like Mike said, measuring strain can be very tricky sometimes so it would help to know what sensor and signal conditioning you are using.
(3,370 Views)
 thanks for replay
i bound the quickpack pzt  sensor to the  flexiable cantilever beam at the fixed end and i have pzt actuators at the fixed end but in the other side
my application is  using pid controller ( active vibration control ) and i need to convert the voltage signal from the pzt sensor to strain or dispacement
i have no problem about the control only i want to convert the pzt sensor signal to strain or dispacement
(3,347 Views)
I know the hardware setup seems irrelevant because you already have it working, but what hardware you're using determines what software tools are available to you.
You can either use a DAQmx task to convert from volts to strain, or the datasheet for your device will have a formula or curve you'll have to implement.
Tanner B.
Systems R&D Engineer - Aerospace, Defense, and Government
(3,304 Views)
