storing output into a array problem
Hi Dennis,
I noticed a wire comming from the left wall of the block (going to Input A), what exactly it is doing? also does it matter if we connect the daq output to Input A?
I will try you solution and let you know.
Sine
Message 11 of 20
(1,625 Views)
Hi Dennis,
Sine
Message 12 of 20
(1,625 Views)
That's a shift register and is a basic element in LabVIEW. And yes it matters if your wire the DAQ output to input A. Input A is earlier data. Input B is the latest data.
Message 13 of 20
(1,621 Views)
Thank you Dennis. Every thing seems to be working. I will do some testing and will let you know. Actually this VI is a part of the bigger system I am trying to design and being a novice, I could not have done it without your help.
Sine
Message 14 of 20
(1,614 Views)
Hi Dennis,
The solution is working only if I am acquiring 1 channel, I modified DAQ assistant to acquire 2 channels and the append signals VI is outputing only 1 channel to write.
Sine
Message 15 of 20
(1,579 Views)
If using multiple channels, I think your best bet may be to convert from dynamic data with selecting 2D array of scalars with columns as channels. Then use the Insert into Array function. For some reason you cannot set up the old data as the top input array, so I just flipped it around to insert at the beginning of the array with the new stuff.
Jeff | LabVIEW Software Engineer
Message 16 of 20
(1,552 Views)
this is continued/double posted here!
Message 17 of 20
(1,548 Views)
Hi Jeff,
I just saw your reply and tried it. Now the x column data is not empty. But the problem is, it now contains the row number and not the time data. How can I get the time column?
Sine
Message 18 of 20
(1,515 Views)
With Jeff's solution, he converted to a 2D DBL array so there is no time information to save.
Message 19 of 20
(1,504 Views)
Dennis is correct. You may want to use the Convert from Dynamic Data and select the 1D array of waveforms instead. Then you can use the Index Array to retrieve the waveform data of a specific channel.
Message 20 of 20
(1,478 Views)
