storing comments into file, newbie at this stuff
If your only intent is to mark certain points of data acquisition, you'll probably be able to get away with something as simple as this:
The actual VI is uploaded here
Message Edited by mishkin on 02-16-2009 03:25 PM
Message Edited by mishkin on 02-16-2009 03:27 PM
Misha
Message 11 of 13
(740 Views)
just what part of the write to measurement function did you wire the element to ? if it is to the comments, my problems would have gone a complete 360 and i would be where i initially started. thanks though. the real issue is that my supervisor doesn't like the switch i put in to place.
my real question is how does labview recognize that i pushed the enter/return key on teh keyboard. i convert my strings into "/" form, hex form, dec form. it appears that it is only in the "/" form does any string indicator actually show that it recognizes the enter key by showing a "/n". i was thinking of trying to convert the string i type into "/" form, look at the last two characters, and see if they equal to "/n". that is the part i was really stuck on.
of course, even if i figured out how to do that, i still would have to figure out how to then erase the string i typed for later text.
i think i will just put that problem in the back of my to do list right now.
Message 12 of 13
(728 Views)
Use an event structure.
Message Edited by Cory K on 02-16-2009 04:13 PM
Cory K
Message 13 of 13
(725 Views)
