store column into matrix
Hello, I'm acquiring some data that comes into a string of numbers. I'd like to store them into a matrix in this way: for acquisition 1 -> data in column 1, acquisition 2->data in column 2 and so on...
I did the code attached simulating some data, but when I put them in the matrix, the new acquisition finishes in column 1 and the old one become a list of 0.
Any suggestion?
ps - I'm acquiring pixel values, so at the end I'd like a pixel matrix to reconstruct an image. every acquisition is a vertical line of the image.
Message 1 of 12
(4,801 Views)
A matrix is a special datatype, mostly for linear algebra and other computations. You want to use a plain 2D array. Keep it in an initialized shift register and add a new row with each iteration using build array.
Message 2 of 12
(4,799 Views)
Thanks! I'll try that!
Message 3 of 12
(4,797 Views)
Do you really need to see the imtermediary result? If the loops are fast, just autoindex on both loop to get a 2D array. Same final result.
Message 4 of 12
(4,795 Views)
Do you have some example?
Message 5 of 12
(4,794 Views)
Hem could you send me the .vi? Thaks!!!!
Message 6 of 12
(4,779 Views)
It just export the last values of the 2 for loops...
Message 7 of 12
(4,776 Views)
Check the attached vi. I recommend you to take LV basics and workout some example to get used to the primitives in LV.
Message 8 of 12
(4,772 Views)
Hi, could you tell me where is the error? thanks
Message 9 of 12
(4,762 Views)
Your VI looks nothing like my example. I cannot really tell what the error is, because you are not telling us what kind of result you get and what kind of result you expect. Do you get an error message?
  • You did not initialize the shift register (right-click the left side...create constant)
  • LabVIEW makes no distinction between row vectors and column vectors. so remove the smaller "build array" and the transposition. Transpose once outside the loop, after it leaves the right shift register. (and also going to the "appended array" indicator if needed). Make the "transposed array" a 1D array and resize it vertically on the front panel.
Message 10 of 12
(4,754 Views)
