store DAQ acquired signal into array
In my program I am acquiring signal using DAQ assistant. I have attached the image of front panel with this post. Now I have to do some averaging and display the result simulteniously with the acquired signal plot.
can anyone help me to do so? I have tried to unbundled the signal but the concept is not working.
(4,172 Views)
HI
Use "convert from dynamic data function" and connect to output of Daq assistant. In the properties of "convert from dynamic data function" select the datatatype you want in Conversion section. (averaging the signal you can use 1D array of scalar automatic).
For acquiring data continuously put while loop to your daq assistant and use append signal VI for appending the signal.
Use shift register and add the data append signal VI.
Hope this helps.
Regards
Santosh
Message Edited by SantoshJaiswal on 03-03-2009 08:12 AM
(4,143 Views)
