stopping the execution in between
I am using so many vis, this is one among some of them are similar to this. I am using all the vis to execute one after another.
Rajashekar
Message 11 of 17
(1,128 Views)
I would recommend you use a state machine architecture; you can use boolean checks to break running loops (which are the ones consuming the most time in a state). Also, you should make your as modular as possible.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
Message 12 of 17
(1,126 Views)
Can you send me the different programming architectures with examples so that i can make best use of it.
Message 13 of 17
(1,122 Views)
I mentioned this in a previous post. In LabVIEW, goto File -> New.. There is a Design Pattern directory which has the different kinds of architectures that can be used....the most popular of them being the Producer/Consumer (Data) and the State Machine architecture.
Adnan Zafar
Message 14 of 17
(1,120 Views)
Thanks for ur help and I have gone through that, other than that any architecture is there?
Message 15 of 17
(1,114 Views)
Adding on to that are some good programming practices which usually comes with experience. There are loads of suggestions mentioned on the forums. You can always email me if you have any questions...just click on my name on the left and you should be able to get my email.
Message Edited by Adnan Z on 04-06-2009 03:04 PM
Adnan Zafar
Message 16 of 17
(1,111 Views)
Instead of State machine is not possible with Event structure.
Message 17 of 17
(1,107 Views)
