stopping a timed loop
Anyone know how to prematurely stop a long duration Timed Loop?  I have a timed loop running at a 10 second rate but would like it to stop immeditaely and exit when the user presses a Stop boolean switch wired to the timed loop stop icon.  I've experimented with simple logic around the 'period' element on both the left and right sides of the loop but the loop just doesn't recognize the stop key press until it times out at 10 seconds.
Dean...
(3,181 Views)
You can use the "Stop Timed Structure VI". Check the online help.
Message Edited by altenbach on 01-28-2010 05:47 PM
(3,170 Views)
Thanks!  That's the solution.  Just missed it on the Timed Loop palette somehow.
(3,150 Views)
