stop without exit
This is completly different woooooow 🙂
But Ray the start Button is not working !!! it  does not do any thing......
LV 8.2
Message 11 of 51
(1,626 Views)
Did you select a DAQ channel first?
And all the other selections that appeared in the popup window?
I was following the logic from the previous version.  As I said, I didn't test the code.
If I have time tonight, I can simulate the DAQ setup and try running it..
RayR
Message 12 of 51
(1,609 Views)
yes I did , the start button is not active at all !!
Also I found out that I have to push exit 2 times to exit the vi
Message Edited by kmous on 01-12-2009 02:18 PM
LV 8.2
Message 13 of 51
(1,589 Views)
I'll have a look...
Message 14 of 51
(1,574 Views)
Oh yes...  I forgot that the START button gets disabled if no DAQ is selected.
That's fixed.  I didn't get a chance to investigate further the need to select EXIT twice.
Does it occur when you exit while running?  or after you stop the acquisition?  or for both situations?
The START button should now be enabled after selecting a DAQ device.
RayR
Message 15 of 51
(1,562 Views)
Ray I have V 8.2 🙂 Could you please save it in v 8.2 ?
thank you
LV 8.2
Message 16 of 51
(1,549 Views)
D'oh!
Sorry about that.  😮  Will do it this evening, unless someone beats me to it.. 😉
Too many project in my head...  LV8.6, LV8.5, LV8.2, C++, Unix.. Makefiles...  😮  Context switching is overloaded 😄
Message 17 of 51
(1,532 Views)
Cool , i did fix the Spirometry probleme using build path and file dialog , it works fine :)So that one is done.
I will add the GUI.vi , u might do some improvments or suggestions .
LV 8.2
Message 18 of 51
(1,529 Views)
btw u are funny and i love it 🙂
LV 8.2
Message 19 of 51
(1,528 Views)
I was funny 😮 ??!!!???!!!???!! 😮
Oh well...  😄
Here's the temperature vi in LV8.2.
Hope it's okay..  😉
R
Message 20 of 51
(1,515 Views)
