stop plot legend names changing
Hi all,
I'm using the X-Y graph for the plot (comparison) of two datasets.
I have manually given each of the two datasets a name which appear in the legend.
The problem is once the graph is updated then the plot name in the legend for one(1) of the plots reverts to "Plot 1".
How do I stop it from doing this?  I want to fix the names of the plots in the legend.
Battler.
(3,032 Views)
Hi Battler,
I can't think why one of the plots would lose it's defined name unless you are setting the data in a bizarre way.
You can always set the plot legend name each time you update the data by using a property node for the XY graph and setting two properties:
1. Set the  ActivePlot property to 1 (0 is the first plot, 1 the second plot)
2. Set the  Plot.PlotName property to your desired string.
Thoric (CLA, CLED, CTD and LabVIEW Champion)
(3,007 Views)
Hi Thoric,
I'm displaying the graph data using an array of two clusters, that's all.
I will try setting the property nodes.
Thanks for your help.
(2,984 Views)
