status:overload:overloadedchansexist
I am using Labview 2011 academic version. I am trying out a vi posted in one of the forum which check for channel overload using DAQmx Read property node.  The option status:overload:overloadedchansexist is present when I browse for Class DAQmx Read properties.  Unfortunately I could not get it into the selectable options.  I have pasted the screen capture below.   Under status the overload group of properties was not listed.  Did I miss something or this properties is no longer available in version 2011.  Thank in advance.
Crawling.
(2,893 Views)
Accepted by topic author Crawling
Rightclick the DAQmx Property Node, and select "Select Filter". In the upcoming dialog select "Show All Attributes". Then you will also find the Overload properties.
Christian
(2,869 Views)
Such a simple solution!.  Thanks Cristian_M for showing the way to a newbie.
Crawling.
(2,844 Views)
Hmm, too bad.  I just found out this property is not supported in cDAQ-9172 and NI 9234.   Just to note in case others meet similar situation.
Crawling.
(2,840 Views)
