state machine and daq
I am trying to prepare a VI that is capable of acquiring, analysing, and recording the results via a state machine but there is someting wrong about acquisition state. I intended to acquire 2 different signals, one of them is temperature and the other is amper. Temperature is acquired precisely but the ampera is not. What could the problem is here?
Egemen
Message 1 of 10
(3,702 Views)
You need to have both of your channels in a single task.
Patrick Allen: FunctionalityUnlimited.ca
Message 2 of 10
(3,688 Views)
Since you are only reading a single value, I don't see a reason to use the start and stop DAQmx task VIs.  Just use the read (it will take care of it all for you).  That might clear some things up.
Another thing I noticed is that you are not closing out your log files.
Message 3 of 10
(3,681 Views)
Actually, I do not understand what you meant whit gathering channels in one task.. Could you explain it explicitly?
Egemen
Message 4 of 10
(3,677 Views)
Yes I have forgotten to close them. I fixed it. Thanks. And also I delete the start and stop functions and it works as it has done before.
Egemen
Message 5 of 10
(3,676 Views)
I could not still handle with it. What do you mean with a single task? I need to acquire 2 anlaog signals from different modules of a compact daq. How could I do it in single task?
Egemen
Message 6 of 10
(3,661 Views)
Hi Egemen,
There's an example that illustrates what I'm describing.
\National Instruments\LabVIEW 2012\examples\DAQmx\Synchronization\Analog Input - Voltage and Thermocouple in a Single Task.vi
Or, you can open the Examle Finder and type "Input".  There should be an example called, "Analog Input - Voltage and Thermocouple in a Single Task.vi"
Message 7 of 10
(3,647 Views)
Hi Patrick,
Thank you for your response but I have Labview 2009 SP. I search to find an example something like you mentioned but I have not found it. Also the case that I am trying to constitute is not synchronization of analog input and analo output. Both of signals are analog inputs. Could you send the example (saved as for 2009 SP1 version) to me ? Thanks in advance.
Egemen
Message 8 of 10
(3,640 Views)
Hi again Patrick,
I found something about multi measurements and attached the snippet. Did you mean something like that?
Egemen
Message 9 of 10
(3,621 Views)
@newbieeng wrote:
Hi again Patrick,
Yes.  That is what you should be doing.  Then for the read, you need to select multiple channels.  The result will be an array, so you will need to index the values out.
Message 10 of 10
(3,589 Views)
