state machine VS producer consumer architecture - Time Analysis
If you want your event to run immediately, enqueue your initialize case in the queue before starting your consumer loop.  It will then run immediately and then sit there waiting to run again once it is complete.  You should also quit your consumer loop on an error so that the stop button can stop it.
Message 11 of 13
(599 Views)
Got it !! Used first call to do that.
Abhilash S Nair
Research Assistant @ Photonic Devices and Systems lab
[ LabView professional Development System - Version 11.0 - 32-bit ]
LabView Gear:
1. NI PXI-7951R & NI 5761
2. The Imaging Source USB 3.0 monochrome camera with trigger : DMK 23UM021
OPERATING SYSTEM - [ MS windows 7 Home Premium 64-bit SP-1 ]
CPU - [Intel Core i7-2600 CPU @ 3.40Ghz ]
MEMORY - [ 16.0 GB RAM ]
GPU - [ NVIDIA GeForce GT 530 ]
Message 12 of 13
(596 Views)
NEW RESULTS of TIME ANALYSIS. Smiley Happy
left - state machine , right - PC architecture.
Abhilash S Nair
LabView Gear:
Message 13 of 13
(595 Views)
