starting while loop with a delay
         A  simple question. Is there a way to start a while loop after 2 sec delay?
thanks.
(4,401 Views)
You could enclose all of your "working code" in a case statement, have the loop running (at whatever loop rate < 2 seconds) and in the "non-working code" case check for an elapsed time of 2 seconds. If you need to have it be more accurate you could have a sub-vi that waits two seconds, but has an internal "first call?" from the "Syncronization pallette, to allow it to wait only the first time through the loop. The first example I gave has the possible error of a whole "loop time", the later is only limited to the accuracy of your timing source.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(4,395 Views)
Accepted by topic author gsajja
Here is what I mean
Putnam
LabVIEW Champion
(4,386 Views)
You could do this.
Tim
GHSP
(4,385 Views)
aeastet,
                 Thanks for the reply. Looks like a possible solution I was looking for.
(4,379 Views)
