starting point of array
i have a 1d array,let say it gos from 0-1000, i want to take out the portion of 200-600,
my  qstn is, how do i specify the starting pt and length?
(3,135 Views)
Use the "Array Subset" function.
(3,134 Views)
Use "Array Subset" to get at that part of the array; use "Delete From Array" to remove that part and return a modified array.
Jm
Jim
(3,125 Views)
"take out" can mean many things, so you should be a bit more clear.
  1. Do you want to take the subset of elements 200-600 for futher processing. Here "array subset" is correct and you'll get a new array  of size=401 where element #0 is the old element #200, etc.
  2. Do you want a new array of size=600 with elements 200-600 missing so the new element at index=200 would have the value of element #601 in the original data. Here "delete from array" would be correct.
  3. Do you want to Keep the array the same size, but set elements 200-600 to zero or NaN? In this case "replace array subset" would be correct.
 Please clarify what you want. 🙂
(3,078 Views)
