starting exe from another exe
Hi all ,
I want to start a exe from another running exe .... from pushbutton .
any idea how to create this
Regards
VBR
(3,696 Views)
VBR,
the function you are looking for is called "System Exec.vi" if the calling executable is built in LabVIEW (otherwise, i asume you wouldnt have posted in the LV-Forum). You can find the function in the connectivity-palette.
hope this helps,
Norbert B.
Norbert
Expert: Geometry
(3,695 Views)
Use a case or event structure with a System Exec.vi in it.
Wiebe.
(3,691 Views)
Thanks Norbert ,
Can you please give breif description about steps to do.
(3,689 Views)
iam using LV 7.1 where i can find system exec.vi ???
(3,688 Views)
system exec.VI  -->ok its in communication palette
(3,686 Views)
Thanks Norbert , Wiebe,
it works... have nice day.
VBR
(3,681 Views)
