starting a terminal
I am new to the industry and very new to labwindows. In my lab we use ProComm Plus, a terminal emulation application to control our hardware via serial connection to our PC's. We can write simple scripts to perform testing on our products, update our products, etc. I am looking for something in LabWindows to do the same. I don't know if there is a terminal emulation already built in or if there is a .c that somebody has written to do it, but I would like to know. Please if anyone can help me I would appreciate it. Thanks.
(3,026 Views)
CVI has a very complete library for serial communication. Programming your own terminal would not be very hard, actually CVI ships with an example that can give you a good idea on where to start.
You should be able to find the example at C:\Program Files\National Instruments\CVI70\samples\rs232\serial.cws This example icludes a nice UI that allows you to configure the serial port.
Let me know if you have any specific questinos on this.
Juan Carlos
N.I.
(3,026 Views)
I looked at that example in the sample folder. Thanks. Do you know of any other examples that do not reside in the ni folder? Possibly online
(3,026 Views)
If you posted this question to the CVI forum instead of the LabVIEW one, you would probably have a better chance of locating the examples you want.
(3,025 Views)
Sure, just go to http://www.ni.com/examples you can serach ther for serial and limit your results to CVI. You should get about 12 hits with different implementations of serial communication.
Good luck!
Juan Carlos.
(3,026 Views)
